Выберете то, что вам нужно
Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
Underneath the piece of plastic you just removed, there is a small screw (Phillips #000, 2.0 mm long). Use a Phillips #000 screwdriver to remove it.
Push on the backplate with both thumbs, sliding it towards the top of the device.
Once it begins to move, lift up slightly. You can then slide the backplate all the way off.
Еще один человек закончил это руководство.
