SanDisk Sansa C250 Internal Battery Replacement
Выберете то, что вам нужно
  1. SanDisk Sansa C250 Internal Battery Replacement, Battery Cover: шаг 1, изображение 1 из 1
    • Slide the back cover forward toward the top of the device with your thumb.
  2. SanDisk Sansa C250 Internal Battery Replacement: шаг 2, изображение 1 из 1
    • The back cover is now separated from the device.
  3. SanDisk Sansa C250 Internal Battery Replacement, Battery: шаг 3, изображение 1 из 1
    • Apply a fingernail or a plastic opening tool to the base of the battery.
  4. SanDisk Sansa C250 Internal Battery Replacement: шаг 4, изображение 1 из 1
    • Lift up gently. The battery should come up and out.
  5. SanDisk Sansa C250 Internal Battery Replacement: шаг 5, изображение 1 из 1
    • The battery is now removed from the device.
  6. SanDisk Sansa C250 Internal Battery Replacement, Rear Case Cover: шаг 6, изображение 1 из 1
    • Remove the two black .265" screws at the base of the device.
  7. SanDisk Sansa C250 Internal Battery Replacement: шаг 7, изображение 1 из 1
    • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  8. SanDisk Sansa C250 Internal Battery Replacement: шаг 8, изображение 1 из 1
    • Slide the rear case cover toward the top of the device with your thumb to release it.
  9. SanDisk Sansa C250 Internal Battery Replacement: шаг 9, изображение 1 из 1
    • The rear case cover can now be separated from the device.
  10. SanDisk Sansa C250 Internal Battery Replacement, Front Case Cover: шаг 10, изображение 1 из 1
    • Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
  11. SanDisk Sansa C250 Internal Battery Replacement: шаг 11, изображение 1 из 1
    • Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
    • CAUTION: Do not fully remove the case cover until the next step has been completed or you may damage the ribbon cable. To be safe, only lift the cover high enough to fit a spudger in the gap.
  12. SanDisk Sansa C250 Internal Battery Replacement: шаг 12, изображение 1 из 1
    • Open the case cover starting on the side most distance from the buttons.
  13. SanDisk Sansa C250 Internal Battery Replacement: шаг 13, изображение 1 из 1
    • Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
  14. SanDisk Sansa C250 Internal Battery Replacement: шаг 14, изображение 1 из 1
    • You can now safely remove the front case cover from the device.
  15. SanDisk Sansa C250 Internal Battery Replacement, Internal Battery: шаг 15, изображение 1 из 1
    • CAUTION: If using a fingernail, be careful not to hurt yourself on the connector.
    • Using a spudger or flat tool, lift the battery up and away from the board, taking note of its orientation.
  16. SanDisk Sansa C250 Internal Battery Replacement: шаг 16, изображение 1 из 1
    • Desolder the connectors on both sides of the battery to remove it.
    • Resolder on a new Panasonic 6Y3 micro cell battery, taking care to orient it correctly as noted in the previous step.
    • Bend the battery back so that it's flat against the board.
Заключение
Еще один человек закончил это руководство.
Ryan Burke
Участник с: 01/23/12
55 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 3-30, Amido Winter 2012 Участник Cal Poly, Team 3-30, Amido Winter 2012
CPSU-AMIDO-W12S3G30
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 18
За всё время: 2,996
