Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Follow this guide to replace a faulty headphone jack in your Sandisk Sansa m230 Series MP3 Player.
  1. Remove the battery compartment cover.
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Locate and remove the screw next to the battery compartment lid.
    • Locate and remove the screw next to the battery compartment lid.
  3. Locate the interlocking pegs along the seam of the device's casings.
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. The battery contact springs may prevent the case from separating.
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. The casing protecting the USB and headphone jacks must be removed.
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  7. You now have access to all components found on the inside of the device!
    • You now have access to all components found on the inside of the device!
  8. Locate the headphone jack on the motherboard.
    • Locate the headphone jack on the motherboard.
  9. Ensure the hot end of the soldering iron is elevated on a metal stand when not in use to prevent burns.
    • Ensure the hot end of the soldering iron is elevated on a metal stand when not in use to prevent burns.
    • The solder and soldering iron are very hot! Do not touch unless you are wearing appropriate protective gloves.
  10. Use soldering iron to melt the existing solder at the three headphone jack connections. Use soldering iron to melt the existing solder at the three headphone jack connections. Use soldering iron to melt the existing solder at the three headphone jack connections.
    • Use soldering iron to melt the existing solder at the three headphone jack connections.
  11. Remove the faulty headphone jack from the motherboard.
    • Remove the faulty headphone jack from the motherboard.
  12. Align the new headphone jack appropriately on the motherboard for soldering.
    • Align the new headphone jack appropriately on the motherboard for soldering.
  13. Use the soldering iron and solder to create three stable connections between the motherboard and the headphone jack. Allow the new solder to cool and harden before reassembling the MP3 player. Allow the new solder to cool and harden before reassembling the MP3 player.
    • Use the soldering iron and solder to create three stable connections between the motherboard and the headphone jack.
    • Allow the new solder to cool and harden before reassembling the MP3 player.
Заключение
James Thorne
Участник с: 05.11.2013
638 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Участник UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 903
