Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement
Выберете то, что вам нужно
  1. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement, Sandisk Sansa m230 Series mp3 player Teardown: шаг 1, изображение 1 из 1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 2, изображение 1 из 1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 3, изображение 1 из 1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 4, изображение 1 из 1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 5, изображение 1 из 1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 6, изображение 1 из 1
    • You now have access to all components found on the inside of the device!
  7. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement, Battery Spring Contacts: шаг 7, изображение 1 из 2 Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement, Battery Spring Contacts: шаг 7, изображение 2 из 2
    • Locate both battery spring contacts, if necessary, on the motherboard.
  8. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 8, изображение 1 из 2 Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 8, изображение 2 из 2
    • Apply heated soldering iron to points where the contacts are soldered to the motherboard.
  9. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 9, изображение 1 из 1
    • Soldering irons, when heated, are very hot and can potentially burn the user.
    • Be sure to always elevate the hot end of the soldering iron on a metal stand to prevent incidental burns.
  10. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 10, изображение 1 из 1
    • With solder melted, remove battery spring contacts from the motherboard.
  11. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 11, изображение 1 из 1
    • Replace spring contacts with new ones.
  12. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 12, изображение 1 из 1
    • There may be some solder in the way of the spring contacts' metal contacts. If this occurs simply melt the solder to create room for the contacts.
  13. Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 13, изображение 1 из 2 Sandisk Sansa m230 Series mp3 player Battery Spring Contacts Replacement: шаг 13, изображение 2 из 2
    • With the new battery spring contacts in place, use the soldering iron to apply new solder to the connection points.
    • Be sure to allow the new solder to cool and harden.
Заключение
James Thorne
Участник с: 11/05/13
638 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Участник UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 701
