Введение
This guide can be used for those that are experiencing difficulties with the hold switch on their Sandisk Sansa m230 Series mp3 player. A faulty hold switch may cause the device to fail to turn on. Use this guide to replace a faulty hold switch.
Выберете то, что вам нужно
Remove the battery compartment cover.
Remove the battery.
Locate the interlocking pegs along the seam of the device's casings.
Gently pry the pegs apart one at a time, working your way around the case.
The battery contact springs may prevent the case from separating.
Push the battery contact springs down through the hole in the case.
The casing protecting the USB and headphone jacks must be removed.
Locate and gently pry apart the two interlocking clips holding it in place.
The outer casings may now be removed and the MP3 player should separate.
Use the soldering iron to liquefy the solder connecting the hold switch to the motherboard.
Liquefy the solder on each contact and remove each contact individually.
With the contacts removed, lift the switch off the motherboard.
With the new hold switch in place, use the soldering iron to solder the contacts between the motherboard and hold switch.
Be sure to allow the new solder to cool and harden.
