  1. Sanitaire SC684 brush roller replacement or cleaning, Belt: step 1, image 1 of 1
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay vacuum on its back
  2. Sanitaire SC684 brush roller replacement or cleaning: step 2, image 1 of 1
    • Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Detach the two latches on either side of the vacuum by pulling outwards towards the wheels.
  3. Sanitaire SC684 brush roller replacement or cleaning: step 3, image 1 of 1
    • Lift off the metal plate by pulling it towards you.
  4. Sanitaire SC684 brush roller replacement or cleaning: step 4, image 1 of 1
    • Identify the belt and brush roller.
    • The belt is a black circle made of rubber.
    • The brush roller has bristles and is tube shaped.
  5. Sanitaire SC684 brush roller replacement or cleaning: step 5, image 1 of 1
    • Slide the belt off of the circular knob.
  6. Sanitaire SC684 brush roller replacement or cleaning: step 6, image 1 of 2 Sanitaire SC684 brush roller replacement or cleaning: step 6, image 2 of 2
    • Pull brush roller out and detach the belt off the brush roller.
Заключение
Caycie Pascual
Участник с: 26.09.2012
1 Репутация
Автор 5 руководств
Cal Poly, Team 16-58, Forte Fall 2012 Участник Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 членов
Автор 10 руководств
0 Comments
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 23
За всё время: 999
