Выберете то, что вам нужно
Using a plastic opening tool, lift the metal backing from the front of the device.
Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
Flip the device so that the front is facing you.
Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
Near the charging port, pull the case away from the motherboard to create clearance to remove the motherboard.
Use the spudger to push the motherboard in and pop the metal edge of the charging port up and inside the plastic case.
Peel the tape off about halfway so that it is no longer attached to the memory board.
6 участников успешно повторили данное руководство.
Один комментарий
thanks a million for this. i accidentally erased the boot partition, bought another one on eBay with a defective audio channel and switched the memory board: eureka! i’m happy listening to my tunes again!
