Введение
Instructions on how remove the LCD display.
  1. Use caution not to damage ribbon when disconnecting. The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Use caution not to damage ribbon when disconnecting.
    • The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
    • Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
  2. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Купить сейчас
    iPhone X Fix Kits
    Купить сейчас
  3. The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
    • The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
Заключение
Jonathan Yau
Участник с: 11.04.2010
26 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 27-95, Amido Spring 2010 Member of Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 3,503
