Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Архивировано
Архивированное руководство
Это руководство сохранено для исторических целей. Используйте его обновлённую версию, чтобы выполнить ремонт.
Архивировано
Введение
Instructions on how to remove the photo array device from the Sanyo VPC-T850
Запчасти
Детали не указаны.
  1. Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Slide out and open the hatch located on the bottom-right side of the camera.
    • In the revealed compartment, move the small notch and push in on the battery to remove it.
    • During reassembly, there is an arrow on the battery indicating which way it goes in.
  2. Using the Phillips #00  Screwdriver, remove the 8 screws located around the sides and bottom of the camera. Look for the screwhead with the label PH00 on the side in the kit provided. Be sure to save these screws in a secure area to ensure they are not lost.
    • Using the Phillips #00 Screwdriver, remove the 8 screws located around the sides and bottom of the camera.
    • Look for the screwhead with the label PH00 on the side in the kit provided.
    • Be sure to save these screws in a secure area to ensure they are not lost.
  3. Using the spudger, slowly pry the rear panel away from the left side. Be careful not to damage the three green cables as you remove the rear panel of the camera. Be careful not to damage the three green cables as you remove the rear panel of the camera.
    • Using the spudger, slowly pry the rear panel away from the left side.
    • Be careful not to damage the three green cables as you remove the rear panel of the camera.
  4. Using the Phillips #00 Screwdriver, remove the 8 black screws connecting the green keypad chip to the rear panel.
    • Using the Phillips #00 Screwdriver, remove the 8 black screws connecting the green keypad chip to the rear panel.
    • Do not put any excessive force on the green wires.
  5. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  6. Separate the rear panel from the rest of the camera assembly.
    • Separate the rear panel from the rest of the camera assembly.
  7. Using the Phillips #00 Screwdriver, remove the 3 screws located across the top of the camera. Using the Phillips #00 Screwdriver, remove the 3 screws located across the top of the camera.
    • Using the Phillips #00 Screwdriver, remove the 3 screws located across the top of the camera.
  8. Carefully pull off the side covers wrapped around the camera. Carefully pull off the side covers wrapped around the camera.
    • Carefully pull off the side covers wrapped around the camera.
  9. Using the spudger, gently pry the front cover of the camera off. As the front cover is fragile, it can easily break if not removed carefully. As the front cover is fragile, it can easily break if not removed carefully.
    • Using the spudger, gently pry the front cover of the camera off.
    • As the front cover is fragile, it can easily break if not removed carefully.
  10. Use caution not to damage ribbon when disconnecting. The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Use caution not to damage ribbon when disconnecting.
    • The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
    • Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
  11. The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
    • The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
  12. Remove the two screws holding the photo array.
    • Remove the two screws holding the photo array.
  13. Remove the foam from the top of the wire connector. Gently remove the plastic connector in the same way as the previous connector of the same type. Lift the connector from the side with the ribbon cable in it.
    • Remove the foam from the top of the wire connector.
    • Gently remove the plastic connector in the same way as the previous connector of the same type.
    • Lift the connector from the side with the ribbon cable in it.
    • Using the spudger, gently push from the right side.
Заключение
Jonathan Yau
Участник с: 11.04.2010
26 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 27-95, Amido Spring 2010 Участник Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,057
