Sanyo VPC-T850 Shutter Button Replacement
Выберете то, что вам нужно
  1. Sanyo VPC-T850 Shutter Button Replacement, Battery: шаг 1, изображение 1 из 1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Shutter Button Replacement: шаг 2, изображение 1 из 1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Shutter Button Replacement: шаг 3, изображение 1 из 1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Shutter Button Replacement: шаг 4, изображение 1 из 1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
  5. Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: шаг 5, изображение 1 из 3 Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: шаг 5, изображение 2 из 3 Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: шаг 5, изображение 3 из 3
    • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
    • Be sure to keep track of the side each screw comes from, as they come in different lengths.
  6. Sanyo VPC-T850 Shutter Button Replacement: шаг 6, изображение 1 из 2 Sanyo VPC-T850 Shutter Button Replacement: шаг 6, изображение 2 из 2
    • Orient the camera so the display is facing up.
    • Gently pull off the rear panel surrounding the display.
    • There are still three green wires connecting the panel to the rest of the camera.
    • Use your prying tool if you have difficulties removing the panel by hand.
  7. Sanyo VPC-T850 Shutter Button Replacement: шаг 7, изображение 1 из 1
    • Remove the eight black screws connecting the keypad circuit board to the rear panel.
  8. Sanyo VPC-T850 Shutter Button Replacement: шаг 8, изображение 1 из 2 Sanyo VPC-T850 Shutter Button Replacement: шаг 8, изображение 2 из 2
    • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
  9. Sanyo VPC-T850 Shutter Button Replacement: шаг 9, изображение 1 из 1
    • Flip the camera over so the lens is facing up.
    • Gently lift up the front panel to remove it from the rest of the camera.
    • Use your plastic opening tool if you have difficulties removing the panel by hand.
  10. Sanyo VPC-T850 Shutter Button Replacement, Shutter Button: шаг 10, изображение 1 из 1
    • Find the chrome framing located on the top of the camera.
    • The physical shutter button apparatus is directly attached to this frame.
  11. Sanyo VPC-T850 Shutter Button Replacement: шаг 11, изображение 1 из 2 Sanyo VPC-T850 Shutter Button Replacement: шаг 11, изображение 2 из 2
    • Remove the three black screws connecting the chrome frame to the camera.
    • Three screws are located toward the front, with the remaining one above the display.
  12. Sanyo VPC-T850 Shutter Button Replacement: шаг 12, изображение 1 из 1
    • Gently remove the loosened chrome frame and connected shutter button from the camera.
Заключение
James Robinson
Участник с: 10/27/15
459 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Участник UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 135
