Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will help you remove and replace the LCD screen.
Выберете то, что вам нужно
Remove the five case screws with a Phillips #00 Screwdriver.
Five 3.5mm Phillips Screws
Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
Gently lift ribbon out of the gate and set screen aside.
