Введение
This guide includes instructions for removing the main board.
The main board consists of the motherboard, plastic frame, flash capacitor, and battery tray. The motherboard cannot be separated from the main board without breaking either of the pieces. Luckily, main boards are sold as one unit.
Запчасти
No parts specified.
  1. Remove the five case screws with a Phillips #00 Screwdriver. Five 3.5mm Phillips Screws Five 3.5mm Phillips Screws
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Gently lift up the back cover and set aside.
    • Gently lift up the back cover and set aside.
  3. Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector. Be careful not to rip out the ribbon connector.
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger. Gently lift ribbon out of the gate and set screen aside.
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
  5. There are five screws of three different sizes which need removal. One 4.5mm screw
    • There are five screws of three different sizes which need removal.
    • One 4.5mm screw
    • Four 3.5mm screws, one on the button side
    • One 5.5mm screws
  6. Slowly lift metal tray to the right. Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Slowly lift metal tray to the right.
    • Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
  7. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  8. Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
    • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
    • One gate is black and another is white.
  9. Remove the three silver screws. Three 5.5mm screws
    • Remove the three silver screws.
    • Three 5.5mm screws
  10. Lift the lens unit free of the camera.  A spudger can be used to separate the lens unit if necessary.
    • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
  11. Remove 4 screws attached to the exterior silver bezel. Four 3.5mm screws Four 3.5mm screws
    • Remove 4 screws attached to the exterior silver bezel.
    • Four 3.5mm screws
  12. Remove round silver bezel from the front of the camera.
    • Remove round silver bezel from the front of the camera.
  13. Remove the two screws on the bottom of the front cover.
    • Remove the two screws on the bottom of the front cover.
  14. Remove tripod mount.
    • Remove tripod mount.
  15. Carefully lift off the front cover plate of the camera.
    • Carefully lift off the front cover plate of the camera.
  16. Remove the flash lens using the spudger or a finger.
    • Remove the flash lens using the spudger or a finger.
    • It will be attached by a piece of tape, peel the lens off of that piece of tape without removing the tape.
  17. Push out pin that holds the door hinge together Pull out the pin. Be careful to keep track of the spring and black spacer. Set the battery door aside
    • Push out pin that holds the door hinge together
    • Pull out the pin. Be careful to keep track of the spring and black spacer.
    • Set the battery door aside
Заключение
Anthony Giardina
Участник с: 19.04.2010
20 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 7-10, Maness Spring 2010 Member of Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 2,138
