Введение
This guide can be used to replace or improve RAM (Random Access Memory) in a Toshiba Satellite L650
Выберете то, что вам нужно
(Right Side-Image 1) Pull clip outwards until it sticks
(Left side-Image 1/2) While pulling clip outwards, pull the battery with your other hand.
(Image 1) Unscrew the screw with a Phillips Head #00
(Image 2) Two clips are located at the top. Dissengage them and lift the panel.
To reassemble your device, follow these instructions in reverse order. See the Reminder boxes, located at the bottom of each step, for certain reassembly instructions.
Еще один человек закончил это руководство.
