Scentsy Warmer Light Bulb Replacement
Выберете то, что вам нужно
  1. Scentsy Warmer Light Bulb Replacement, Light Bulb Replacement: шаг 1, изображение 1 из 1
    • Unplug the device's power cord from the electrical outlet.
    • If the warmer was running before you turn it off and unplug the device from its outlet, wait for the warmer to cool down (approximately 15 minutes) before you continue to the next step.
  2. Scentsy Warmer Light Bulb Replacement: шаг 2, изображение 1 из 1
    • Remove the wax warmer dish from the device.
  3. Scentsy Warmer Light Bulb Replacement: шаг 3, изображение 1 из 2 Scentsy Warmer Light Bulb Replacement: шаг 3, изображение 2 из 2
    • Carefully unscrew the light bulb from its socket in a counterclockwise direction.
    • Remove the light bulb from the device.
  4. Scentsy Warmer Light Bulb Replacement: шаг 4, изображение 1 из 2 Scentsy Warmer Light Bulb Replacement: шаг 4, изображение 2 из 2
    • Check the wattage of the light bulb at the bottom of the device.
    • Make sure you have the correct wattage for the new light bulb in hand to replace the old one with.
  5. Scentsy Warmer Light Bulb Replacement: шаг 5, изображение 1 из 1
    • Screw in the new light bulb in a clockwise direction.
  6. Scentsy Warmer Light Bulb Replacement: шаг 6, изображение 1 из 1
    • Place the wax warmer dish back on top of the device.
  7. Scentsy Warmer Light Bulb Replacement: шаг 7, изображение 1 из 1
    • Plug the power cord back in to the electrical outlet.
  8. Scentsy Warmer Light Bulb Replacement: шаг 8, изображение 1 из 1
    • Add in a few cubes of wax.
    • For a mid size or larger warmer such as this one, use two cubes at a time, at the most. For a smaller size warmer, you only need one cube at a time. Adding more than the suggested cubes of wax to a warmer could lead to the wax not being melted all the way.
    • Turn the device on.
    • Make sure the device is powering on by observing the light indication.
Заключение
Once complete, the warmer should turn on and melt the wax completely, creating a good fragrance in your household.
2 участников успешно повторили данное руководство.
Uyen Lawless
Участник с: 04/11/20
230 Репутация
1 руководство автора
Команда
Eastern Washington University, Team S25-G3, Crane Spring 2020 Участник Eastern Washington University, Team S25-G3, Crane Spring 2020
EWU-CRANE-S20S25G3
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 27
За последние 30 дней: 115
За всё время: 5,805
