Введение
Does your screen door no longer close gently like it used to? Does it ever close behind you on
your ankle before you have both feet in the door? Not only can this be annoying but it can also
hurt! This a simple fast fix on how to replace your old screen door closer with a new one.
Выберете то, что вам нужно
Make sure the door is completely closed. push up from the bottom to remove the pin from the bracket that connects the barrel to the door frame and release the door closer barrel.
Slide the new clip (metal washer that was provided with the door closer) on the door closer barrel with the dented side facing inwards (as shown in photo).
Slide the bracket away from the barrel until there is no slack. Tighten screws on the bracket.
Test the door and if there are any issues (i.e. door closing too fast or too slow). Make necessary adjustments to the tension screw.
2 участников успешно повторили данное руководство.
