Введение
Save yourself some money by replacing your screen door mesh with this guide. This guide assumes that you've already removed the old mesh and spline.
Выберете то, что вам нужно
Place the screen door on a completely flat surface. Lay the new screen across the frame.
Use tape or clamps along the bottom edge of the screen to keep it taut against the frame.
Use the convex (pointy) edge of the screen rolling tool to gently push the mesh into the frame channel along the top of the frame. This will create a crease for the spline to be inserted into.
Use a pair of scissors to make a diagonal cut at the corner of the frame. This will give the mesh some "relief", and prevent it from bunching up in the corners.
Start the spline in the top corner by pressing it into the frame channel with your fingers. Don't worry about getting it fully inserted — the screen rolling tool will handle the rest.
Use the convex (grooved) edge of the screen rolling tool to press the spline into the frame channel. Make sure to keep the screen taut while doing this.
When you reach the corner, use your hands to route the spline around the corner.
Once you reach the bottom (taped) edge, partially remove the tape to make another diagonal cut in the mesh.
Remove the tape section by section, and continue creasing and pressing the spline into the frame channel.
Keep working in the same manner until you reach your starting point.
Once you reach your starting point, trim the spline so that it will fit snugly up against the beginning edge of the spline without any overlap.
The screen rolling tool does a great job of getting the spline into the frame channel, but it doesn't always get the spline fully inserted. Carefully use a flathead screwdriver to push the spline into the frame channel until it is snug.
Housing came and renewed the Mesh the front Mesh is loose you can push the Mesh outwards behind the security Door how do I tighten the Mesh
Carefully use a utility knife to trim the excess mesh around the frame. You can use the outer edge of the channel and spline as a guide to get a straight, clean cut.
18 участников успешно повторили данное руководство.
9 Комментариев
really helpful; my problem is i have huge lanai windows that need to be rescreened; its very daunting because you cannot lay them down, you are working in mid air; the basic principles here will apply but how do you get started. Even just tucking the screen back in where its become loose is hard to do without it bagging out or sagging here and there. Thanx, will help when I do the door.
Start with the top side!
nicO -
Really helpful guide, thanks! I made an edit to omit the part about making sure the small squares in the mesh align with the frame because (as I experienced in my case) the mesh wasn't cut perfectly parallel, so there wasn't enough overlap if I aligned them this way. I think the most important part is to just make sure there's enough overlap on all sides.
Nice article. Thank you for sharing this. Its really helpful. Step by step instruction on door replacement is good. We expect more from your side
Amazing blog, Screen Door Mesh Replacement is a useful and informative post. So thanks for sharing. ++http://canopytechnology.co.nz/++
My door has 3 diagonal bars in which the mesh is supposed to be. Di I install the outer seam first? Or the middle bars?
My screen door has two sliding windows (one at the bottom and one at the top) with attached screens. I can roll the top window down and the screen attached comes with it. The window rubber spline has came loose which has caused the window to now be cock-eyed and the screen to be torn. How can I fix this issue?
In advance, appreciate your help.
Lee at “nuclear@aol.com”
2/14/23
See above comment
