Введение
Is your old saw blade just not getting the job done anymore? Is your blade cover not doing anymore covering? Use this guide to replace your saw blade and blade cover and restore the saw to prime condition.
Выберете то, что вам нужно
Although this is not a difficult fix, it can definitely make a mess.
Lay down a dirty towel or work rag and place the saw on top of the towel.
Use the crescent wrench to remove the hex washer head screw and the washer.
Gently lift the blade up and pull it off of the internal threaded shaft.
