Введение
A guide to remove the intake fan from the Sega Dreamcast.
Запчасти
Никакие детали не требуются.
Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
Добавить комментарий
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Note: Remove the expansion bay to locate the fourth screw
Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
Remove the white fan header by gently pulling it away from from the controller port.
  • Remove the white fan header by gently pulling it away from from the controller port.
  • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
Remove the two 8.5mm Philips #00 screws from the fan bracket.
  • Remove the two 8.5mm Philips #00 screws from the fan bracket.
Remove the two 17.5mm Philips #00 screws from the fan bracket. Remove the fan from the bracket.
  • Remove the two 17.5mm Philips #00 screws from the fan bracket.
  • Remove the fan from the bracket.
Заключение
2 участников успешно повторили данное руководство.
wkwong
381 Репутация
Автор 13 руководств
Команда
Cal Poly, Team 5-1, Regan Fall 2009 Member of Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 членов
Автор 23 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 2
За 7 дней: 5
За 30 дней: 24
За всё время: 5,994
