Введение
A guide to remove the Logic Board from the Sega Dreamcast.
Выберете то, что вам нужно
Flip the console over on its back.
Take note of your model number, in case replacement parts are needed.
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
Turn the console right side up.
Remove the top cover by gently lifting the upper portion of the console.
Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
Do not bend the male pin header between the mounted head when you remove the power supply from the chassis.
Remove the power board by using both hands to gently lift the power board away from the console.
Remove the clear plastic film that is tucked between the power supply and the chassis.
Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
Remove the white fan header by gently pulling it away from from the controller port.
Remove the two 17.5mm Philips #00 screws from the fan bracket.
Remove the fan from the bracket.
Remove the five 10mm Philips #02 screws from left side of the logic board cover.
Remove the three black 12mm Philips #02 screws from the right side of the logic board cover.
17 участников успешно повторили данное руководство.
One Comment
helpful but my dreamcast had a different logic board and as well as fan and gd-rom so keep that in mind if u see something different in your unit
