Введение
This guide will lead you in replacing the earpads on a Sennheiser HD 599 SE. This easy process will allow you to replace the worn-out earpads with new ones for a more comfortable listening experience.
Grip the underside of the earpad. Try to dig in as much as possible in order to get the best grip.
Snap the earpad in. Make sure to apply pressure on one side and work your way around until the earpad is secure.
To reassemble your device, follow these instructions in reverse order. Make sure to only use Earpads that are compatible with the Sennheiser HD 599 SE as using any other Earpad will damage your Headphones.
2 участников успешно повторили данное руководство.
