Выберете то, что вам нужно
Turn the laptop upside down and gently lay it down on a flat surface.
Slide the battery release latch to the right and the battery will pop up slightly.
While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
Remove the Phillips PM2.0×4.0 screw using a PH#00 screwdriver.
With an opening tool pry off the tabs that secure the service door to the base enclosure. Start with the long edge.
Continue along the short edges.
Once you have pried the service door off as it is in pic#3, it will come out of the rear edge very easily.
RAM memory modules
HDD (Hard Disk Drive)
mSATA SSD slot
Wifi & BT module (Wireless card)
