Введение
If you are having a problem with your device's Front motor, Here is a Step by step guide to replace a faulty or broken Front motor.
Выберете то, что вам нужно
Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
3 участников успешно повторили данное руководство.
