Введение
Step by step guide on how to remove the filter if it needs to be replaced or cleaned. The filter can be easily accessed by using the release push button on the dust cup. Depending on how full the dust cup is, you should be prepared for dirt and debris to come loose upon removing the filter.
Separate the dust cup by pressing the grey push button on top of the vacuum and pulling it apart from the body.
Pull the filter out of dust cup.
Clean the filter using cool water and let it dry completely before inserting it back into the container.
2 участников успешно повторили данное руководство.
