Введение
This is not a replacement guide. Use this to make your Shark DuoClean Powered Lift-Away Speed replacements more manageable. No special tools or skills are required.
Press the Wand Release button and pull up on the metal tube to remove the entire hose.
Press the Lift Away button and pull up on the handle to separate the top of the vacuum from the bottom.
Еще один человек закончил это руководство.
