Введение
Wire cutting and soldering may be required for more info on soldering visit the iFixit soldering guide.
Выберете то, что вам нужно
Squeeze Dust Cup release buttons on either side of the component.
Pull up to release Dust Cup.
Remove the two 15 mm screws by twisting counterclockwise with the T10 Torx screwdriver.
Remove the two 12 mm screws by twisting counterclockwise with the T15 Torx screwdriver.
To fully remove the power cord, cut the wires using a wire cutter.
2 участников успешно повторили данное руководство.
