Введение
You will need a T10 Security Torx screwdriver and an iFixit Opening Tool to open the side components.
Выберете то, что вам нужно
Open the garage door by sliding both of the release buttons away from you.
Lift off the garage door.
Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
Еще один человек закончил это руководство.
