Введение
Following this guide requires cutting wires and soldering. For more information on soldering visit the soldering guide.
Выберете то, что вам нужно
Squeeze Dust Cup release buttons on either side of the component.
Pull up to release Dust Cup.
Remove the five 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
Remove the two 15mm screws by twisting counterclockwise using the T10 Torx screwdriver.
Remove the two 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
Remove the two 15 mm screws holding the motor cover by twisting counterclockwise with a T10 Torx screwdriver.
2 участников успешно повторили данное руководство.
