Shark ION Robot R75 Main Brush Replacement
  1. Shark ION Robot R75 Main Brush Replacement, Main Brush: шаг 1, изображение 1 из 1
    • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
  2. Shark ION Robot R75 Main Brush Replacement: шаг 2, изображение 1 из 1
    • Pull the main brush slightly to the right to remove it from the compartment.
  3. Shark ION Robot R75 Main Brush Replacement: шаг 3, изображение 1 из 2 Shark ION Robot R75 Main Brush Replacement: шаг 3, изображение 2 из 2
    • Remove the rubber end cap indicated by the red circle.
    • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
    • Inspect this component at least every six months. This time may be less if you have animals.
Заключение
Kyle Wilbourn
Участник с: 01/25/20
513 Репутация
Автор 4 руководств
Команда
Один комментарий
My shark ion stopped working after about 6 months and it started giving an error on the brush. I cleaned my vacuum pretty regularly, at least once a week. I ordered a replacement brush and it still hasn't fixed it. Do you have any other suggestions?
Tina Hicks - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 15
За последние 30 дней: 80
За всё время: 2,579
