Shark ION Robot R75 Side Brush Replacement
Выберете то, что вам нужно
  1. Shark ION Robot R75 Side Brush Replacement, Side Brush: шаг 1, изображение 1 из 3 Shark ION Robot R75 Side Brush Replacement, Side Brush: шаг 1, изображение 2 из 3 Shark ION Robot R75 Side Brush Replacement, Side Brush: шаг 1, изображение 3 из 3
    • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
    • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
Заключение
Kyle Wilbourn
Участник с: 01/25/20
513 Репутация
Автор 4 руководств
Команда
2 Комментариев
I have removed/lost my screw that went inside the side brush. Do you have screw size recommendation to replace it? Shark doesn't sell them and says the brush may fall off if I don't have my screw. Is it guaranteed that Phillips #1 Screwdriver would be able to remove screws? I have tried all types of screwdrivers and haven't found one to remove the other screw to take it to the store to find the right size to replace what I am missing.
Kell S - Ответить
Our Shark AV1002AE needs a Torx T-9 to remove the screw. However we have not found a replacement screw or insert
Kathy - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 28
За последние 30 дней: 179
За всё время: 6,011
