Введение
This guide will show you how to replace the two filters on the top of the motor unit of the Shark IONFlex 2X.
With normal usage, the filters will not need to be replaced, but will need to be rinsed and air dried for 24 hours prior to re-insertion in the machine once every month.
  1. Squeeze the lever labeled “Clean Filters Monthly” and pull up on the plastic cover. Squeeze the lever labeled “Clean Filters Monthly” and pull up on the plastic cover.
    • Squeeze the lever labeled “Clean Filters Monthly” and pull up on the plastic cover.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Grab the white foam filter inside and pull out.
    • Grab the white foam filter inside and pull out.
  4. Grab the larger side of the black plastic ring on the side of the white filter, and separate the white foam filter from the inner filter. Grab the larger side of the black plastic ring on the side of the white filter, and separate the white foam filter from the inner filter. Grab the larger side of the black plastic ring on the side of the white filter, and separate the white foam filter from the inner filter.
    • Grab the larger side of the black plastic ring on the side of the white filter, and separate the white foam filter from the inner filter.
Заключение
Kendal Cler
Участник с: 28.09.2015
789 Репутация
Автор 6 руководств
Команда
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 5
За всё время: 56
