Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Replacing these filters can help reduce the abnormal noise and improve the smell of the vacuum.
  1. Locate the latches on the side of the dust cup, the clear plastic chamber in the center of the vacuum.
    • Locate the latches on the side of the dust cup, the clear plastic chamber in the center of the vacuum.
  2. Pull the bottom of the latch with your hand in an upward direction. Lift the top of the latch up and away from the dust cup using your hand. Repeat the above steps with the latch on the other side of the dust cup.
    • Pull the bottom of the latch with your hand in an upward direction.
    • Lift the top of the latch up and away from the dust cup using your hand.
    • Repeat the above steps with the latch on the other side of the dust cup.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Lift the dust cup up and away by its handle on the top with your hands. Lift the dust cup up and away by its handle on the top with your hands.
    • Lift the dust cup up and away by its handle on the top with your hands.
  5. Lift the foam filter up, out, and away with your hands. Lift the foam filter up, out, and away with your hands. Lift the foam filter up, out, and away with your hands.
    • Lift the foam filter up, out, and away with your hands.
  6. Lift the felt filter up, out, and away with your hands by the tab on the top. Lift the felt filter up, out, and away with your hands by the tab on the top. Lift the felt filter up, out, and away with your hands by the tab on the top.
    • Lift the felt filter up, out, and away with your hands by the tab on the top.
Заключение
Pramika Kumar
Участник с: 30.09.2017
165 Репутация
1 руководство автора
Команда
Cal Poly, Team S15-G2, Livingston Fall 2017 Участник Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
3 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 14
За последние 30 дней: 46
За всё время: 1,843
