Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement
Выберете то, что вам нужно
  1. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement, Roller Brush Belt: шаг 1, изображение 1 из 2 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement, Roller Brush Belt: шаг 1, изображение 2 из 2
    • Lay the vacuum down by hand and locate the roller brush underneath the vacuum cleaner.
  2. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 2, изображение 1 из 3 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 2, изображение 2 из 3 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 2, изображение 3 из 3
    • Insert the metal spudger between the inside side of the wheel and the plastic body.
    • Push the metal spudger away from you to pop the wheels out.
    • Repeat the step to remove the other wheel on the other side.
  3. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 3, изображение 1 из 1
    • Remove the six 15mm screws using the PH1 screwdriver.
    There are also 2 screws up near the top of the picture past the wheels. Note, there are 2 wheel screws as well, but you don’t need to remove those. You want the 2 deepest screws at very top. Also note, the top left most screw circled in the picture above is the only screw longer than all the rest because of the design.
    Bryan Hawkins - Ответить
    I have these as well. Reading the same in the comments was reassuring! You can see the holes in the photo where the screws are missing from.
    Andrew Reed -
    Mine has tore security screws with the pins in the center.
    sval229 - Ответить
    I had to remove 10 screws before Step 5 worked for me. But it’s fixed! Gratifying.
    Janet - Ответить
    Before you start check the screw heads, on ours they were TR20 Torx Security.
    As well as two extra screws hiding up near the main wheels.
    LordGarrey - Ответить
  4. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 4, изображение 1 из 2 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 4, изображение 2 из 2
    • Move the blue fulcrum connecting the bottom and the main body of the vacuum cleaner back and forth to loosen up crevice between the two halves of the roller brush enclosure.
    The separation is not occurring with multiple tries to the point of stressing the plastic.
    Bob - Ответить
    All 6 screws removed
    Bob - Ответить
    I'm having the same problem, all 6 screws removed and I cannot get the pieces apart without breaking the plastic, feels like there is something else holding the two parts together behind the main wheels
    Brock Josephson - Ответить
    There are two more screws down in the back below the wheel assembly that have to be removed as well because I also roughed up my plastic before taking them out and then it came right apart.
    Pam Osterhoudt - Ответить
    What Pam said. There are 2 extra screws behind the wheels, next to the other 2 screws at the back of the housing.
    Enzo the Baker - Ответить
    Shark may make a good vacuum, but I don't know if I will buy one again or suggest for anyone to buy one. When they make routine replacements so hard
    hdarnell15@yahoo.com - Ответить
    Plus, the clip that keeps the top lid of the debris collecter closed also has to bear the full weight of the appliance when it is picked up by the handle that is part of the lid. The clip is much too flimsy to do that often and breaks easily. POOR DESIGN‼️‼️‼️and POOR ENGINEERING but good news for the replacement parts profit center. 😾🤔🤬🤥👹👎🏻👎🏻👎🏻
    Unique username - Ответить
  5. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 5, изображение 1 из 3 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 5, изображение 2 из 3 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 5, изображение 3 из 3
    • Insert the plastic opening tool into the crevice between the blue and the dark grey plastic frames enclosing the roller brush.
    • Apply an outward force throughout and all around the gap in order to separate the two plastic frames.
    I did not find it necessary to pry the pieces apart, but your experience may very.
    I cannot get the grey frame to separate. It seems stuck around the wheel area. All other areas are separated. I am afraid I will crack the 'plastic if I apply any force. Any thoughts?
    Mary T Sullivan - Ответить
    Did you remove all 10 screws? Yes, there are a lot more than 6.
    IVAN BJELOPERA - Ответить
  6. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 6, изображение 1 из 2 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 6, изображение 2 из 2
    • Lift the grey frame off the bottom of the vacuum cleaner with your hands and place it on a flat surface.
  7. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 7, изображение 1 из 3 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 7, изображение 2 из 3 Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 7, изображение 3 из 3
    • Lift the roller brush slightly upwards using your hand.
    • Take one side of the black roller brush belt off by pulling it over the end of the roller brush with your other hand.
  8. Shark Navigator Lift-Away Deluxe NV500 Roller Brush Belt Replacement: шаг 8, изображение 1 из 1
    • Remove the roller brush belt with your hands by sliding it of the end of the motor.
Заключение
5 участников успешно повторили данное руководство.
Elena Postupalskaya
Участник с: 10/02/17
1 159 Репутация
Автор 6 руководств
Команда
Cal Poly, Team S15-G2, Livingston Fall 2017 Участник Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
3 членов
Автор 14 руководств
8 Комментариев
Whhhhyyyyyy does this require a special, hard to find bit to disassemble!!!!! I have screw driver set with everything from philips, standard, Allen and even the star bits. But they had to go a use one with a %#*@ peg in the middle rendering all my tools useless. Had I known I would never have bought it.
Forrest Sutton - Ответить
I agree, Yeah why!
Ellen Long -
You can by a tamper proof hex set for like $7 on Amazon.
My roller brush is just locked. I have the hair cleaned out but it won’t budge. Is there a release button somewhere?
Amy Johnson - Ответить
I need to know the same thing please
April McClure -
My roller brush is broken it won't come on it's not clogged built is fine it's on the right position switch
Alan Johnson -
Yah they suck, I just happened to have a set of tamper proof aliens, but they were still a ##&&% to get out. 15 min my ass , more like 2 hrs. But when it came to reassembling it I threw those screws sway and replaced them with regular Phillips screws, it went together fast with my screw gun, and if I have to replace the belt again It will be a breeze.
Mike zeni - Ответить
? I don't understand what's up for me
Alan Johnson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 20
За последние 7 дней: 112
За последние 30 дней: 411
За всё время: 36,330
