Shark Navigator Motor Replacement
Выберете то, что вам нужно
  1. Shark Navigator Motor Replacement, Roller Brush Compartment: шаг 1, изображение 1 из 1
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Motor Replacement: шаг 2, изображение 1 из 2 Shark Navigator Motor Replacement: шаг 2, изображение 2 из 2
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Motor Replacement: шаг 3, изображение 1 из 1
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Motor Replacement, Motor: шаг 4, изображение 1 из 1
    • Once the vacuum top is opened, you can simply remove the motor as shown in the image.
    • Make sure to untangle or unhook any wires that are connected to the motor.
    • Once this is done, you can replace the old motor with a new one.
Заключение
Molina Oung
Участник с: 03/27/15
265 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team 5-4, Kish Spring 2015 Участник UMass Dartmouth, Team 5-4, Kish Spring 2015
UMASSD-KISH-S15S5G4
4 членов
Автор 16 руководств
4 Комментариев
Hi Where could I get a replacement motor from for NV501 model shark rotator .Or have the same motor rebuilt...Any help would be appreciated thank you.....
jacob - Ответить
The screws on the bottom of roller brush compartment ARE NOT phillips head!!!!!!!!!!!!!!!!!!!!
randy - Ответить
The screws are Phillips on mine. It may be a case of availability. If the manufacturer found a better deal on a different style of screw, they may have changed it.
Joe Evans -
Mine has the security Torx screws. Those are the Torx bits with a round hole in the center. Anyway, what is the model number of the motor? I need a replacement motor, and am finding several in eBay but don't know which one is correct.
Roger -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 16
За последние 30 дней: 74
За всё время: 14,500
