Shark Navigator Roller Brush Compartment Replacement
Выберете то, что вам нужно
  1. Shark Navigator Roller Brush Compartment Replacement, Roller Brush Compartment: шаг 1, изображение 1 из 1
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Roller Brush Compartment Replacement: шаг 2, изображение 1 из 2 Shark Navigator Roller Brush Compartment Replacement: шаг 2, изображение 2 из 2
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Roller Brush Compartment Replacement: шаг 3, изображение 1 из 1
    • Remove the white plastic cover to expose the roller compartment underneath.
Заключение
19 участников успешно повторили данное руководство.
Jeremiah Shyne
Участник с: 03/27/15
1 403 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 5-4, Kish Spring 2015 Участник UMass Dartmouth, Team 5-4, Kish Spring 2015
UMASSD-KISH-S15S5G4
4 членов
Автор 16 руководств
16 Комментариев
Tried driver tips on two MULTI-TIP tools (standard & metric), but none fit. Looks like a very small 6-sided star w/a hole n middle. Trying again tomorrow w/mini metric set. I agree, 10 screws, two under wheels is way too much trouble for something you need quick access to often for brush cleaning. The hose has several places where it comes apart very easily. I was impressed, but this roller plate ruined it.
Bettie Howard - Ответить
Nice guide very easy to follow took awhile to complete only because vacuum parts I took off with very dirty had to clean other than that the guide was very very useful and very very easy to follow appreciate it!!!
Kenneth Johnson - Ответить
Easy to get off but hard to get it bqck on. I put the name of my shark and took it apart and it was for a lift away which I dont have now I can’t get it back together HELP
Gail Jezik - Ответить
Where did you find the replacement brush bar? Im having a heard time locating one.
meghmrr - Ответить
This truly is not intended for the user to replace the roller, but rather, they would like you to pay a lot more to take it in to service! To have a star screw with hole - which is what mine has - not Philips - and under wheels and 10 of them of varying length, and good luck, like Bettie Howard said, getting the driver to fit into the deeper holes! I have no adapter or extension - means you’d have to purchase a special tool. Luckily for me, I didn’t have to replace the roller, but rather sucked a USB cable which quickly wrapped around it. I was trying to salvage it, but after 2.5 screws later, decided it was better to cut the cable!
a_1_jensen - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 24
За последние 30 дней: 57
За всё время: 86,170
