Shark Navigator Roller Brush Replacement
Выберете то, что вам нужно
  1. Shark Navigator Roller Brush Replacement, Roller Brush Compartment: шаг 1, изображение 1 из 1
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Roller Brush Replacement: шаг 2, изображение 1 из 2 Shark Navigator Roller Brush Replacement: шаг 2, изображение 2 из 2
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Roller Brush Replacement: шаг 3, изображение 1 из 1
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Roller Brush Replacement, Roller Brush: шаг 4, изображение 1 из 1
    • Lift the roller brush out of its holders.
Заключение
42 участников успешно повторили данное руководство.
Jeremiah Shyne
Участник с: 03/27/15
1 403 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 5-4, Kish Spring 2015 Участник UMass Dartmouth, Team 5-4, Kish Spring 2015
UMASSD-KISH-S15S5G4
4 членов
Автор 16 руководств
35 Комментариев
Instructions where so easy to follow & right on the money. It took me 11 min from start to finish. PERFECT!!!
Cole bohn - Ответить
Very helpful and easy. Thank you.
Kristi cox - Ответить
Thank you. The owner's manual doesn't take into account needing to disassemble to clean the brush, for those of us with super long hair. Your instructions pointed out the screws under the wheels that we were missing.
birdofpyre - Ответить
Ive uscrewed everything and this white piece seems to be stuck toward the rear. I even took the back whells off.
falynkinsey - Ответить
Thank you so much. After having had to send in vac due to recall could not bare to part with it again to fix the belt. Your instructions for very clear and easy to follow. Thank you June
interhome1 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 58
За последние 30 дней: 255
За всё время: 99,146
