Введение
This guide takes a bit more advanced steps from removing the motorized brush belt. After opening the motorized brush head, the motor is easily accessed. Caution should be used when handling the motor, damage or mishandling will inhibit use of the vacuum. Ensure device is de-energized before handling.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver to remove the five 14mm screws from the face of the motorized brush.
Remove the brush roller by lifting vertically away from the brush head. It should come out easily along with the belt.
Lift the motor from the motor mount.
Use a soldering tool to carefully soften the solder on the connectors.
Еще один человек закончил это руководство.
Прикрепленные документы
2 Комментариев
This is the closest I’ve come to finding out how to fix the motorized brush. Thank you. Everything works fine, but what I need now is the little white plastic piece that goes on the motor’s drive axle. Mine is cracked and keeps sliding off. Since Shark.com doesn’t go into this type of detail, is there a generic equivalent I can use? If so, where can I get one, or some. I suppose superglue would work, but I would rather get a new piece.
Any idea where a can get replacement gears
