Введение
To access the innermost components including the electronic valve and heating element, opening the mop body is required. Before doing any disassembly on your Shark Professional Steam Pocket Mop, make sure to unplug the mop and empty the water tank for your safety.
Выберете то, что вам нужно
Unwrap the power cord from the handle.
Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
Pull the handle to separate it from the body.
Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
Remove the plastic cap.
Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
Remove steam control button cover with a metal spudger.
Remove the two 12.0 mm Phillips head #2 screws underneath.
Remove the plastic rim with clear plastic cover.
Remove the Shark logo decal on the front of body using a metal spudger.
Pull out the plastic cover to remove.
Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
Remove the two 12.0 mm Phillips head #2 screws that hold the power cord to the device.
Pop open the white plastic mop body by pulling apart from the front and back side.
2 участников успешно повторили данное руководство.
