Введение
Mineral buildup can occur when the water tank cap is not loosened before storing or if the tank is not drained. In these situations the cap can become stuck inside the tank. When this occurs, the cap is often lost or misplaced, which leads to a replacement.
Remove the water tank cap from the water tank reservoir.
Turn the cap towards the upward position.
Rotate counter-clockwise until it loosens.
2 участников успешно повторили данное руководство.
12 Комментариев
Need a water cap for S3901 N3 11 Shark steam mop. They said they discontinued and I have ordered two online and neither will work. And I really going to have to buy a new one?
Same here did you come across one
Did you find any place that sold these caps? I’m in the same boat need a new water cap.
Rick -
hola a mi trapeador shark lift away no le sale vapor y es nuevo tendra algun defecto?
