Введение
This guide is to help consumers remove the rotary belt from their Shark rocket HV301. Be sure to have the proper tools and replacement parts available prior to beginning this guide.
Выберете то, что вам нужно
Flip the vacuum so the bottom base is visible.
Gently pry the bottom two wheels off with a plastic opening tool.
Remove five visible screws with a Phillips #2 screwdriver.
Locate and twist the three plastic screws to the unlock position with a quarter or flathead screwdriver.
Use a Phillips #2 screwdriver to extract the three screws revealed from removing the plate.
Turn the vacuum over so the rotary brush is on the ground.
Grab the vacuum on both sides of the hose and pull up to remove the top of the vacuum halfway.
Gently pinch the head of the cable and pull upwards until the casing disconnects from the vacuum.
Proceed with removing the upper casing.
Use a Phillips #2 screwdriver to remove the four visible screws securing the rotary brush to the vacuum.
Remove the rotary belt on right side of vacuum from the bearing.
Gently lift the casing to remove the belt and brush from the vacuum.
Gently pry off the plastic casing on both sides of rotary brush.
Lift the clear plastic shell from the rotary brush.
15 участников успешно повторили данное руководство.
3 Комментариев
Where can I find the rotary belt for the Shark Duo?
I could not get it out without removing the brush roll motor. So I am putting it back together and I need to know if the motor has a top and bottom. What I mean is does it matter ? Thank you
Thanks for the guide it came in super handy
