Введение
When the vacuum is failing to pick up dirt or spitting it back out, check the roller brush for damage. Multiple missing or broken bristles as well as a broken or cracked brush can fail to pick up dirt .
Выберете то, что вам нужно
Pull the handle while pressing the lift away button to remove the body of the vacuum.
Flip the base of the vacuum over to access the bottom.
Remove the two small wheels with a metal spudger.
Remove the nine 16 mm screws using the Phillips #2 Screwdriver. Press on the side tabs in the middle of the panel and pull up to reveal the screw under the hose connection.
Remove the two 13.5 mm screws using the Phillips #2 Screwdriver.
Pull up on the cover and move it to the side.
Remove the wire attached to the base by squeezing the pin and pulling up.
Remove the two 11 mm screws using the Phillips #2 screwdriver.
Lift the roller brush cover up.
5 участников успешно повторили данное руководство.
6 Комментариев
Good day, I have a rotator lift away NV500 my belt indicator light stopped working but I was still getting suction. I replaced the filters and hep filters,as well as changed the belt. I cleaned off the dust and then carefully put the vacuum back to gather. I went to plug it in all worked until I pushed the roller brush indicator on and it still did not work. What else could it be? Any suggestions.
I await your reply
Angela
Same here what would be wrong with it
Great instructions - the 11mm hidden screws plus one more were tricky to find. Thanks so much for the great graphics and very clear disassembly steps; I almost gave up and was going to take it to a dealer for a costly repair fee. Thanks again!
Great directions and guidance - many thanks!
