Введение
The Shark Rotator Powered Lift-Away has one rotatory belt. The belt is responsible for the mechanical rotations of the brushroll. Without it, the vacuum will not function. The vacuum's belt is designed to last approximately 7 years. Replacement of the belt is needed to keep the vacuum at optimal working condition. This replacement guide demonstrates how to replace the belt in the vacuum.
Выберете то, что вам нужно
Turn the vacuum on its side.
Using a quarter, twist the three green locks to the unlock position.
Pull the bottom roller brush cover to open the vacuum.
Remove the three 14.3 mm screws with a T20 screwdriver.
there is also a small ~13mm PH0 screw on the center of the edge in front of the roller between the 2 other screws indicated that must be removed before you can get the cover off.
Remove the two 15.9 mm screws from behind the wheels with a T20 bit screwdriver.
Remove the single 13.4 mm small screw behind the roller brush with a PH0 screwdriver bit.
Remove the single 13.4 mm screw from behind the belted end of the roller brush with a T20 screwdriver bit.
Turn the vacuum around.
Using a spudger, pry the top of the vacuum cover off. There are three tabs behind each of the clear rectangles below the headlights.
Remove the grey side panel on the motor side of the vaccum with a spudger. Pry under each tab to release the side panel.
Remove the single 13.4 mm screw located next to where the belt was detached, securing the motor in place, with a PH1 screwdriver.
Remove the grey panel from the opposite side, by uncrewing the single 13.4 mm screw with a PH1 screwdriver. This will release the container for the roller brush and belt motor.
Using the spudger, push the white end cap out of the clear plastic by placing the spudger on the roller brush side and pushing the cap outward.
Remove the belt from the gear.
Thank you for posting this. I couldnt find these instructions anywhere else.
2 участников успешно повторили данное руководство.
2 Комментариев
Where can we buy belts in UK?
where cn i get a belt for this vaccum
As a general comment. Take care and good luck with this procedure. Instructions are fine, I found just one small screw wasn't covered. Front centre in roller cavity near the centre tab. Taking apart was straightforward, then it all feels like a jelly. Bits start moving and falling off as you turn the vacuum around, spring fell off plus other bits. Eventually got it back together, but not so easy, very fiddly. Anyway it works now. MikeM
Mike Mason - Ответить
