Введение
The Shark Rotator Powered Lift-Away has multiple filters to ensure a better clean as compared to other models. This vacuum has a foam and felt filter which should be cleaned every three months so that the vacuum can perform at its best. Another filter the vacuum has is a HEPA filter which helps traps dust and allergens inside the vacuum. The HEPA filter should be cleaned at least once a year. This replacement guide shows how to replace the foam and felt filter.
  1. Press on the lift away button  and pull away from  the vacuum. Press on the lift away button  and pull away from  the vacuum. Press on the lift away button  and pull away from  the vacuum.
    • Press on the lift away button and pull away from the vacuum.
  2. Press down on the hose release button and pull away from the vacuum. Press down on the hose release button and pull away from the vacuum.
    • Press down on the hose release button and pull away from the vacuum.
  3. Pull the dust cup release latch and lift the dust cup from where it rests. Pull the dust cup release latch and lift the dust cup from where it rests. Pull the dust cup release latch and lift the dust cup from where it rests.
    • Pull the dust cup release latch and lift the dust cup from where it rests.
  4. Pull out the  foam filter from where the dust cup rested. Pull out the  foam filter from where the dust cup rested.
    • Pull out the foam filter from where the dust cup rested.
  5. Pull out the felt filter from where the foam filter rested. Pull out the felt filter from where the foam filter rested.
    • Pull out the felt filter from where the foam filter rested.
Заключение
Еще один человек закончил это руководство.
Sujey Ruano
Участник с: 08.10.2018
562 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S4-G6, White Fall 2018 Участник Cal Poly, Team S4-G6, White Fall 2018
CPSU-WHITE-F18S4G6
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 32
За всё время: 508
