Shark Rotator Powered Lift-Away Speed Headlight Replacement
Выберете то, что вам нужно
  1. Shark Rotator Powered Lift-Away Speed Headlight Replacement, Headlight: шаг 1, изображение 1 из 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement, Headlight: шаг 1, изображение 2 из 2
    • Flip the vacuum on its underside, and use a coin to rotate the cam-screws on the bottom panel so that their grooves are parallel with the front of the vacuum.
  2. Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 2, изображение 1 из 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 2, изображение 2 из 2
    • Squeeze the sides of the roller brush cover release clasp, and swing the cover open.
  3. Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 3, изображение 1 из 1
    • Using a T20 screwdriver remove five 15.9 mm screws on the outside of the cover.
  4. Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 4, изображение 1 из 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 4, изображение 2 из 2
    • Using a T20 screwdriver, remove three 13.4 mm screws from where the roller brush cover attaches to the bottom of the vacuum.
  5. Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 5, изображение 1 из 1
    • Using a T20 screwdriver, remove two 13.4 mm screws from under the wheels.
  6. Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 6, изображение 1 из 1
    • Using a T20 screwdriver, remove two 15.9 mm screws behind the vacuum wheels.
  7. Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 7, изображение 1 из 1
    • Using a PH0 screwdriver bit, remove the single 13.4 mm screw in between the roller brush and where the release clasp was attached.
  8. Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 8, изображение 1 из 1
    • Using a T20 screwdriver, remove the single 13.4 mm screw from behind the belted end of the roller brush.
  9. Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 9, изображение 1 из 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 9, изображение 2 из 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 9, изображение 3 из 3
    • Flip the vacuum into the upright position, and use a spudger to open the front assembly cover by prying the seam where the colored front assembly and the grey side covers meet.
  10. Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 10, изображение 1 из 1
    • Separate the front assembly cover from the vacuum.
  11. Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 11, изображение 1 из 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 11, изображение 2 из 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 11, изображение 3 из 3
    • Use a spudger to remove the headlight covers by prying the seams where the headlight covers meet the bottom front of the vacuum.
  12. Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 12, изображение 1 из 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 12, изображение 2 из 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 12, изображение 3 из 3
    • Pull the LED headlight strand up and away from where it is attached to the bottom front of the vacuum.
  13. Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 13, изображение 1 из 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 13, изображение 2 из 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: шаг 13, изображение 3 из 3
    • Pinch the tabs on the circuit board clasp for the LED headlight inwards , and pull the clasp up and away to detach the headlight.
Заключение
2 участников успешно повторили данное руководство.
Dakota Rodriguez-Ransom
Участник с: 10/08/18
605 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S4-G6, White Fall 2018 Участник Cal Poly, Team S4-G6, White Fall 2018
CPSU-WHITE-F18S4G6
4 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 11
За последние 30 дней: 21
За всё время: 2,009
