Введение
The Shark Rotator Powered Lift-Away has two LED headlights to assist in vacuuming in poorly lit areas. The vacuum's headlights are designed to last approximately 7 years. Replacement of the headlights is needed to keep the vacuum at optimal condition. This replacement guide demonstrates how to replace both LED headlights in the vacuum.
Выберете то, что вам нужно
Flip the vacuum on its underside, and use a coin to rotate the cam-screws on the bottom panel so that their grooves are parallel with the front of the vacuum.
Squeeze the sides of the roller brush cover release clasp, and swing the cover open.
Using a T20 screwdriver, remove three 13.4 mm screws from where the roller brush cover attaches to the bottom of the vacuum.
Using a PH0 screwdriver bit, remove the single 13.4 mm screw in between the roller brush and where the release clasp was attached.
Using a T20 screwdriver, remove the single 13.4 mm screw from behind the belted end of the roller brush.
Flip the vacuum into the upright position, and use a spudger to open the front assembly cover by prying the seam where the colored front assembly and the grey side covers meet.
Use a spudger to remove the headlight covers by prying the seams where the headlight covers meet the bottom front of the vacuum.
Pull the LED headlight strand up and away from where it is attached to the bottom front of the vacuum.
Pinch the tabs on the circuit board clasp for the LED headlight inwards , and pull the clasp up and away to detach the headlight.
2 участников успешно повторили данное руководство.
