Введение
When the roller brush is not spinning because of a broken belt or damaged teeth, you might want to consider replacing the belt.
Выберете то, что вам нужно
Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
Using a coin, turn the big white knobs located above the roller brush counter-clockwise.
Lift up the suction hose to reveal a screw.
Remove the 12.7 mm Phillips #02 screw.
Remove eight 12.7mm screws located under the vacuum using a Phillips #02 screwdriver.
Remove two 12.7 mm screws located next to the wheels with a Phillips #02 screwdriver.
Turn the vacuum upright and pull the white upper section of the brush roller circuit housing.
Remove the connector attached to the circuit boards using a plastic opening tool.
Remove the two 12.7 mm screws located at the top of the clear plastic brush roller housing using a Phillips #02 screwdriver.
Lift the clear plastic brush roller housing.
Remove the roller brush by sliding it out toward the left, off the belt.
Remove the belt from the motor gear by sliding the belt away from the gear and belt motor.
