Введение
Before beginning this guide, ensure that the device is both unplugged and cool; failure to do so may result in electrocution or burns.
Выберете то, что вам нужно
Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
Remove the back cover piece.
Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
Pull the split end of the power cord upward through the ball joint.
Set aside the power cord.
Use the Philips head #0 screwdriver to remove the remaining 6.58mm screws that hold the wires on the bottom (brown and blue).
Remove from left to right
Unclip the black adapter piece on the bottom right.
Use the Philips head #0 screwdriver to remove the two 9.75mm screws (left and right) affixed to the circuit board.
Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
Gently pull the circuit board from affixed position.
Remove the mode display piece and set aside.
Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
Remove the connecting wire from the connected adapter in the handle by pulling lightly.
Set aside the circuit board.
5 участников успешно повторили данное руководство.
4 Комментариев
Where can u buy the circuit board professional 1800 version?
How much does the circuit board cost? and where can i purchase it?
