Введение
Before beginning this guide, ensure that the device is both unplugged and cool; failure to do so may result in electrocution or burns.
Выберете то, что вам нужно
Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
Remove the back cover piece.
Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
Pull the split end of the power cord upward through the ball joint of the iron.
Set aside the power cord.
Use the Philips head #0 screwdriver to remove remaining 6.58mm screws that hold a wire on the bottom (brown and blue).
Unscrew from left to right.
Unclip the black adapter piece on the bottom right.
Use the Philips head #0 screwdriver to remove two 9.75mm screws (left and right) affixed to circuit board.
Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
Pull the circuit board out from its affixed position.
Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
Remove and set aside the mode display.
Еще один человек закончил это руководство.
