Выберете то, что вам нужно
Remove the two screws at the back of the iron.
Remove the back cover piece.
Remove the two screws holding the white clamp to the iron.
Remove the two screws holding the black wires to the body of the iron.
Pull the split end of the power cord upward through the ball joint of the iron.
Set aside power cord.
Remove remaining screws that hold a wire on the bottom (brown and blue).
Unscrew from left to right.
Unclip the black adapter piece on the bottom right.
3 участников успешно повторили данное руководство.
3 Комментариев
i am trying to replace the thermal cutoff but can’s remember the wire inside how to replace
I have a constant leak in the vertical position - long after the iron is cold. The repair presented is well done. However it stopped short and doesn't get to the reservoir - thanks
Then WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT?
