Введение
Many vacuum cleaners have a separate pet hair and power brush head. The roller brush of the head can easily break due to wear and tear. Use this guide to replace the internal roller brush in the power brush head of your Shark vacuum cleaner.
Выберете то, что вам нужно
This Shark model brush head consists of 7 parts: a base frame, a gear, a roller brush, two side screws, a plastic round band, and a top frame of the head.
Push the grey button on the back panel to open up the brush head.
Take the new roller brush and fit the two grey screws/fittings on either side of the roller brush until they are secure.
6 участников успешно повторили данное руководство.
13 Комментариев
Cat hair will jam up in the small gap between the gear and the bushing on the turbine and will cause enough friction to stop the turbine. I used a needle to dig out the hair and it solved the problem.
Great tip! It works now! TY!
perfect solution, could find the problem
very clear and concise. took me 5 minutes with your instructions - couldn’t find anything like this on the shark site.
I need to put back all parts , don’t know where to start, can u explain step by step how to put them back please . Thank you
