Введение
This guide will show you how to replace the brush roller motor belt on the power nozzle of the Shark IZ682H.
Выберете то, что вам нужно
Detach the power nozzle from the vacuum and turn it so the right side is facing you. Pull down the blue tab to the direction where the arrow is facing.
The brush roller should now pop out.
Turn the three plastic locks to the unlocked position and remove the crevice tool.
Use T9 and T15 screwdrivers to remove the seven screws.
Use an opening tool on the edges of the casing and pull off the thin plastic coverings on both sides.
Pull the plastic coverings off the powerhead.
Remove the six screws using a T15 Torx security screwdriver.
Remove the plastic headcover.
Remove the seven screws using the T10 and T15 Torx security screwdriver.
Lift the covering and motor assembly enough to see the belt.
Еще один человек закончил это руководство.
